Page 3 of 11 FirstFirst 1234567 ... LastLast
Results 41 to 60 of 205
Thread: Any tune basics for the 65RFE ?
  1. #41
    Oct 2009
    326
    It locks up really early, and I don't like the feel of the "partial lock" that it does. Also, there are times while driving on the freeway that it will hover between locking and unlocking (or partial locking).
    I looked over the tables and had a hard time making out what rpm values they were referring to. Nothing that I was logging matched up to those values (turbine rpm, output rpm, engine rpm).
    Really I'm just looking for some tips on how to go about adjusting it, even if it's just what pids to log.
  2. #42
    Banned
    Jan 2018
    Everywhere
    1,772
    Lockup/unlock is based off of throttle position vs turbine speed. Getting rid of partial lockup between shifts is a whole other ball game. Raise up your unlock to part lock tables if you don?t want it lock up so early.
  3. #43
    Jan 2020
    I have a 2011 RAM 1500 with the 545rfe. I realize the transmission is the same as 65rfe, but does this programming info carry over. I'm considering making a switch to the HPTuners from Diablo. Thanks for any and all info!
  4. #44
    Feb 2020
    3
    I cant find the enable 2-3 shift anywhere under transmission on hptuners. Also under shift pressures it only shows duty cycle for upshift. There is nothing else to change under shift pressures.
  5. #45
    Banned
    Jan 2018
    Everywhere
    1,772
    They probably didn?t map out the 2-3 shift enable or anything else for shift pressures.
  6. #46
    Feb 2020
    3
    Who didnt map it out? Hptuners? Is there a way i can make it available? Sorry for the newb questions. I changed everything i could and it is shifting much firmer now just really want to enable the 2-3 shift
  7. #47
    Banned
    Jan 2018
    Everywhere
    1,772
    Have you tried the Beta version to see if what you are seeking is available on Beta?
  8. #48
    Feb 2020
    3
    Yea im on the beta. I looked under the regular version also and its the same.
  9. #49
    Banned
    Jan 2018
    Everywhere
    1,772
    Sent you a pm
  10. #50
    Feb 2020
    Chatham-Kent Ontario Can
    4
    2-3 shift enable/disable is Trans-shift general ECM 489
  11. #51
    Feb 2020
    4
    Quote Originally Posted by JWM_Jankowitz View Post
    I did everything as outlined in Chad's guide. All I can say is WoW! What a difference. I did however also followed what someone was mentioning as far as a lower duty cycle to make it less harder shifting... All good but... got a MIL P0868 - Transmission Fluid Pressure Low (Pending, Current, Permanent). Can anyone help guide me how to fix this in my tune...
    Attachment 94646
    Appreciate any kind of help here.
    Thanks,
    Mouritz
    change your max pressure ECM 15582 to match your max pressure lock ECM 10099 or vise versa
  12. #52
    Mar 2019
    44
    Thanks Bear71, will certainly try that.
  13. #53
    Banned
    Jan 2018
    Everywhere
    1,772
    I dunno about lowering the shift duty cycles and being soft on the clutches. I would be worried of slippage and burning them myself. Personally on my 68RFE I run true full locked shifts, lockup in 2nd and stay locked up all the way up to 6th and get more aggressive with duty cycle in the higher gears.
  14. #54
    someone share a tune for 2011 please
  15. #55
    Aug 2020
    New York
    Quote Originally Posted by Tadias48 View Post
    Figured it out. I kept hitting the tcc lock right before the 2-3 shift I just raised the apply speed to 2200+ and it solved it.
    Which tables did you change for this?
  16. #56
    Aug 2017
    Quakertown PA
    547
    Quote Originally Posted by Jim P View Post
    Jim can that be done on the RFE65?
    04 RAMGTX........ 8.82@154mph 392Ci G3Hemi 3250lbs 2.6HP/Ci Naturally Aspirated
    05 Rumble Bee 13.29@101mph STOCK 5.7l , Just a tune, still runs OEM airbox
    09 Challenger Drag Pak 8.65@160mph 426Ci G3hemi 3650lbs 2.4HP/Ci Naturally Aspirated
    G3 Hemi Videos
  17. #57
    Banned
    Jan 2018
    Everywhere
    1,772
    Quote Originally Posted by PurpleRam View Post
    The full lock upshifts?
  18. #58
    Aug 2017
    Quakertown PA
    547
    Yes
    G3 Hemi Videos
  19. #59
    Banned
    Jan 2018
    Everywhere
    1,772
    Yea it can be done on the 65RFE. The two transmissions have pretty much the same parameters, some are just set differently from one another.
  20. #60
    Banned
    Jan 2018
    Everywhere
    1,772
    Can PM me if interested in it. Would come at price though. Chances are I would be needing to do a bunch of mapping out as I don?t have many tune files of the 65RFE and the tune would have to be locked. I?m not giving out open tunes anymore that have deep level customization.
