@NITROBRAIN06, how is your repository coming along? I am needing an sc base map as well, no luck from anyone else.
Check out the thread named Toyota Repository. A ton of people have loaded some files in and may be some help for you.
In the middle of tuning a 19 with a 5.7 and magnuson aftermarket. Got it working great when i realized the pcm connection was loose.
We had removed a piggy back and one of the clips broke.
So alas i got it running awesome and the next flash i try to load it says controller init failed. Is the server just down for maintenance?
Come to find out it was user error. My user error.
I went to flash it and forgot to disconnect the battery.
Luckily the customers piggy back was able to reset it
I'm having some trouble just today. Ive tuned other Tundras and never had issues. Just purchased one for myself and it failed to write the file i've adjusted. Controller init failed. How did you get this back going? I have a crank, no start situation now on my own truck!Tundra fail write.jpg
