Results 1 to 5 of 5
Thread: Audi Battery Replacement Code Update
    Jan 2019
    34
    I have used the HP Tuners software to delete some cats on my Vette and so i know the software is quite capable. Does anyone know if HP tuners can change the battery code on an Audi? My S5 battery died and to replace the battery i need to update the battery code at the same time so it will charge properly. If anyone has instructions to do this i would appreciate it.
    Huck
    Jul 2019
    Wilmington, MA, USA
    155
    I don't think so. HP will only talk to specific control units and depending on year/model for Audi will generally only work with the engine and possibly transmission control units. The battery info is stored in one of the body-related control modules, central electrics maybe?
    Anyhow what you need is VCDS (aka "VAG-com") or something similar. If you look on Audi forums like Audizine there is tons of info on battery replacement including coding.
    Jan 2019
    34
    Quote Originally Posted by ELaw View Post
    Thanks for the info. I am little bummed that the HP tuner can't "do it all". I will check out Audizine as you mentioned. Thanks, Huck
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,018
    Quote Originally Posted by Huck271 View Post
    lol, the cable costs $299, ask a shop that "does it all", and ask them how much they have invested in software, cables, and scanners to allow them to do it all. It is tens of thousands of dollars. I feel the level of functionality that we get for $299 is insane
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    May 2019
    4
    You need the VAGCOM cable for things you're talking about... just buy it, as you can also change tons of other parameters on the vehicle (e.g. drive mode settings, lights, warning buzzers, etc.).
