Can I use HPTuners scanner to adjust the settings for my Throttle Position Sensor??
Long ago I modded my TPS by expanding the slots for the screws, so that you can slowly turn the TPS and adjust the settings at idle and full throttle with a voltmeter.
Can I do the same thing with the HP tuner scanner?
What are the optimal settings for idle and full throttle?
I have searched on the forum, and I found .43 Volts at closed throttle, and 5.0 volts at full throttle.
What should I use?
