Results 1 to 7 of 7
Thread: 426 N/A Just when you think ya got it Idle surge out of no where
    May 2019
    North Carolina
    22
    Ok been a while since I had to revise the tune on my car but here we go.
    car ran great in Hawaii moved to North Carolina still ran good. now the car has only made short trips its whole life no more than 10 miles at a time. i now drive this beast 19 miles on the highway to work. The adaptives are what i believe is messing with me. (as i can reset them and the problem goes away until after my next highway trip.)
    it will surge going from D or R to P/N also when putting it into gear it throttles up and has to steadily come back down. so when going from R to D leaving a parking lot it gets all out of whack and surges all over the place until i reset the adaptives. Ive also noticed hot starting it cranks for a while before it lights like 2-3 seconds. in the log im posting it shows a bit of the surge from r-n and d-n not the crazy wild stuff when it really acts up. Hopefully some GURU's on here can help me out. Specs on the build are in the signature. Gettin ready to go standalone just to be rid of these adaptives. Please take a look guys let me know what you think or hopefully know. everything ive done to this tune has been learned from this forum and the tuning school material. its by far the largest cam ive tuned in a Gen 3 Hemi it runs like a bad ass puttin 618HP to the tires on Torco 110 all motor. just wish to get rid of these nasty idle surges. any help is appreciated guys.
    H5 NC 426 22 large and small range idle.hplH5 NC 426 22 large and small range OCN.hpt
    6.1 based 426 stroker fully forged 11.5:1 compression.,Thitek CNC 6.1 Heads, RLD H5 Camshaft, Edelbrock Victor II intake manifold, Hellcat cnc ported TB, FIC 725 cc/min injectors, Legmaker CAI, UPR catch can, BBE 3in exhaust, 3k stall converter , Paramount Nag1, 1K Hp driveshaft and axels, Wavetrac LSD. 400 shot laughing gas on progressive controller. Fore dual pumps with fc3 controller.
    Mar 2018
    45
    One thing to try is increasing the values in the GS Torque Reduction table.
    May 2019
    North Carolina
    22
    Ok I’ll give it a shot and let you know how it does in a few hours
    May 2019
    North Carolina
    22
    No dice it actually made it worse pulling throttle putting it into gear made it almost die going into drive then made the car lurch forward as it tried to stay running.
    May 2019
    North Carolina
    22
    Anyone else running a choppy cam in a 426 that would share their tune file for reference. I’m thinking I’m missing something that may be obvious?
    Oct 2019
    ATL
    57
    Quote Originally Posted by chriscward71 View Post
    not trying to be flippant... but if the adjustment you did made it worse.... why not return it to the original values and then adjust it in the opposite direction to see what the affect of the opposite adjustment is?
    Mar 2009
    S. Florida
    583
    6.1 15lbs boost cam.hpt6.1 base 426.hpt
