It's pulling down to -22 degrees of timing or you are only allowing the computer to drop to +22 degrees of timing?
You always want a timing pull on shifts. Part throttle can be more than full throttle. Like have it drop to -10 to 0 degrees on light throttle and but depending on combo try to have at least some negative timing pull on the shift to help the transmission out.
