Results 1 to 7 of 7
Thread: 392 Challenger SRV issue
    2015 Challenger 392 A8. 218/226 114 cam. I'm having an issue with the SRV valve shutting at 5700 rpm then re-opening at 6100 during a dyno pull. Just wondering if anyone else has seen this? I have played with the rpm enabled and disabled tabs and can only get it to just not open. Pic is with it enabled with it shuttling on the red pull. Blue pull is with it disabled.
    SRV_disabled.hpl SRV_enabled.hpl Heinz_cam_stkinj_cal.hpt
    827
    I wonder if those P2008 and P2016 codes have anything to do with it?
    Those are old codes from a couple runs I did with the srv unplugged.
    827
    Make another run and log short runner valve pwm.
    I'm not seeing and pids related to the srv in the scanner. I was able to log it with a snap on scanner. It's definatly on, then off, then on again. Maybe some missing tables?
    Advanced Tuner Blue Bee's Avatar
    Mar 2017
    DFW
    330
    What is your aircharge when this happens, as in just before, and just after? Yes, there is a couple tables missing that control SRV, so you may not be able to fix this.
    I logged it in the first post. It changes very slightly. A few hundredths. Kinda figured we were missing tables.
