Post your what you have now for a tune with your progress and lets see how it looks. A log with the rich idle would also be good.
I will post it tomorrow its definitely chooo chooing now runs better than ever I got the idle leaned out using the VE table i was thinking other things adjusted the idle afr so i changed a bunch of stuff trying to get it leaned out and then put back after i found the ve table would change the idle in park afr. i still got some supper rich spots in the mid/ high throttle but its better than lean and i can actually adjust it now thanks for everyone's help
Just keep working sections of the table at first and keep it smooth instead of going for individual cells. If you know it's really rich in an area just take a good bit out in that entire area. Eventually you will get where it's close and you can fine tune more but this will get you there quicker and keep things smooth so you don't have spots that are good and then just a bit more throttle or RPM and it's way off again
interesting read....
Do you have a good turbo tune for your 5.7 hemi? Can I see what you have? I'm working on mine but I'm unsure if I'm headed in the right direction..
Very good read fellahs. I'm in my infancy stages of gathering information for my Twin Turbo 6.4 project. I will use some of these tips and ideas for my tuning when the time comes for me to take that step. Thanks for posting.
hey guys im having a problem, i have a 5.7 hemi that i turbo'd and an ngc3 computer. the problem im having is when the turbo starts to build boost it shuts the throttle blade. i can only reach 12.8 psi map and wont let it go higher. i have a mopar 3 bar map sensor and scaled correctly any help??
What are you using for boodt control. The firdt thing anyone is going to ask is to look at your tune as you may have some limits set for your map.
what did you have to do to the injector pulsewidth vs fuel mass and the injector pulsewidth offset for the vacuum referenced fuel pressure regulator as I have just installed a return line and an Aeromotive fpr on an srt4. Im also confused because the tables are such low resolution.
