Results 1 to 3 of 3
Thread: Vats delete Stock vehicle, starter checks needed ?
    Sep 2017
    15
    Vats delete on stock vehicle, is starter checks enabled or disabled ?
    basically is the checks needed for the bcm to function correctly or
    is the starter checks just for the pcm ?
    STOCK vehicle, not a swap.
    Mar 2011
    Ripley, MS
    1,865
    Disable the starter checks as well. That will allow it to start, even if there is a security issue.
    Sep 2017
    15
    Did disable vats and disable starter checks write entire, bcm will not trigger starter.
    ANY suggestions ?
    2013 van is current one.
