Results 1 to 3 of 3
Thread: How do you secure your Laptop during data logging?
    Dec 2018
    7
    Hi Everyone. I am curious what has worked for you to keep the laptop from flying around the car and being dangerous or getting damaged when you are data logging? I would prefer something that is not permanent, it will only be used during my data logging drives.
    How did you secure it? What has worked for you?
    If you have any pictures post them up please.
    Cheers, Steve
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,023
    i used to have a mount, that had a flat plate at the bottom that slid between the passenger seat and the center console. It worked good, was just cumbersome and time consuming to mount the laptop to the mount, then get it set just right so you can view it. Honestly now I just set my laptop in the passenger seat, and drive carefully. Unfortunately, it does go flying sometimes, but a good ssd and the laptop tends to be pretty resiliant
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Dec 2018
    7
    Thanks mbray. My fear is that some of my tuning will be on a road race track. I definitely will need to have the laptop held down well as there will be some G's going on.
    Just getting started on tuning. Test mule is my 69 Camaro with a n/a dry sump TSP built 418. E38, wide band, PWM ZL1 fuel pump (58 psi), long tube headers, TSP stage 3 cam, PRC 260 heads, LS3 intake. T56 mag trans, 3.90 Tru-trac.
