Mine goes away when it's cold out... only this bad when it's warm/hot out so i'd say it's real. Whoever thinks it's false just pull 10 degrees of timing in this area and see if it is reduced. This will only work if you disable Knock Learn though, or monitor Knock learn when you pull the timing, see if it ends up at a much lower value. It will take awhile for that table to lower.
