![Quote](images/misc/quote_icon.png)
Originally Posted by
darens
So I do know how a diesel works. I know about enough about thermodynamics to know you will never know how to set a fixed timing that will work for everyone. Its all based off fuel pressure and pulse width and spray pattern of your injectors and temperature. I know adding boost to any engine increase combustion temp. On a diesel higher combustion temp means faster the fuel will ignite so you would decrease timing. Its fine if you all don't want to give up your secrets on tuning I get that. But if someone calls me on an generic sbc running on the street I can tell them a good place to start on fuel pressure, timing, injector pw to get them started. I understand that diesels are different but I still think there is good starting points out there. Like when you said 12.5kpsi and 14.5kpsi in the cruising region. That is experience with the 5.9 that I am looking for. Some that has a go to when they start setting up one of these
