Results 1 to 12 of 12
Thread: DFCO Settings to get rid of pop
    Jan 2020
    27
    Hey guys. I'm tired of my super aggressive DFCO settings that were done for a ton of pop and bangs while it transitions. Was fun for a while but grew old.
    After a bunch of reading, I think I am going to try the ZR1 stock settings as people report that has no popping.
    Should the timing seems very high on the ZR1 tables. Is this safe to run in my car? C6 LS3.
    Feb 2020
    Metro Detroit Area
    323
    You can disable it all together........
    Feb 2017
    miami
    1,799
    I'm curious what sort of config you have that results with that behavior? It sounds like a delay before fuel cut was induced. Why not simply remove the delay
    Aug 2018
    295
    Increase the timing in the DFCO table. Move it up in 5 degree increments for starters until the pops start to go away.
    Jan 2020
    27
    Quote Originally Posted by kingtal0n View Post
    Very low entry and exit spark does this. I didn't touch the delay.
    I am just curious if the ZR1 numbers are too high for an LS3.
    Feb 2017
    miami
    1,799
    hmm idk any chance its just a leaking injector?
    Early induction to a fuel cut means no more fuel which means no pops.... unless injectors are leaking
    interesting though, I know DFCO can be weird. I'll have to try I guess
    Aug 2018
    295
    If you start raising entry spark table, it will help.
    Jan 2020
    27
    I made it pop. I took more timing out of the decel vs my stock tables.
    Stock tables were much lower than the ZR1. I now want the opposite - no pop. I was just curious if the ZR1 tables are too positive in the timing for entry and exit spark.
    Quote Originally Posted by RobZL1 View Post
    I did some tests last night driving around.
    First incrased both entry and exit by 5 across the board, helped a little, but factory tune was -5 initially down low in the exit table.
    I am now up to 10 lower in the exit table and 20 up top and it has helped a lot.
    Entry is 20 flat across the board was 10 on my stock tune.
    Appreciate everyone's help.
    Feb 2017
    miami
    1,799
    DFCO has been on my list of things to figure out. A long time ago some one told me that DFCO does not fully shut down the injectors.
    I am still wondering if this is true and how we can tell.
    I was going to put a switch on my injector harness so I can manually ensure complete power cut during dfco to determine if there is any difference.
    Its not like any fuel cut in any ecm I have ever encountered.
    Jan 2020
    27
    It doesnt completely shut them off. I log around 1-3% duty cylce depending on RPM if DFCO is enabled.
    There still needs to be some spark and fuel or the car will die, correct?
    Aug 2018
    20
    No, the wheels keep the engine turning. It has a disable rpm so it doesn't get too low and bog or die. I'd be surprised if any fuel is being deliveried. My wideband definitely is maxed out lean.
    Feb 2017
    miami
    1,799
    Quote Originally Posted by lowmpg View Post
    my wideband also shows lean, but I get two things:
    1. scanner shows injector duty is active
    2. fuel smell during deceleration *only*
    my car is smell-free the entire time it runs, only in decel I get this strange fuel smell most notable 30-40mph decelerating sometimes with the cutout open,
    It might be something with the engine vacuum, like injector seals or something. Maybe its pulling is leaves and twigs from the engine bay lol and im smelling burning paper. But still curious that the HPtuners scanner would report some duty in a fuel cut- every other stand alone I've ever seen would say 0%
