Can't disable clutch and decel fuel cutoff
Tuning a 2017 Camaro and have changed all the dfco/cfco values to disable but still seeing lean spikes on clutch and decel.
Any other ways to disable and get consistent scan readings?
Am I asking wrong? More info needed?
There have been a few threads on this lately, a quick search would've helped you some. The consensus I've seen is it's not consistent, best bet is to make sure you're logging enough channels to use filtering to clean up the logs
I've read through all I could find already and like you said, nothing conclusive. So yeah, searches done, and no, didn't help much.
Was hoping it has been figured out
