Results 1 to 10 of 10
Thread: E85 Timing Tables vs 93 octane
    May 2020
    16
    Hello everyone! I am new to the HP Tuners, but I've been a Technician my entire life. I have recently had my 2017 Camaro SS dyno tuned to a point at a local speed shop. I had everything installed, he set up the E85 but there are no timing adjustments on the flex fuel table and there are certain points where the timing drops off from the stock tune. Any one have this issue or is there any suggestions to adjust timing to the best settings?
    Dec 2018
    Dallas Texas
    35
    Can you post the file? Is it stock with just flex fuel?
    Aug 2009
    Calibrating
    3,379
    Lots of tables need modded to make FF work like it should!! But if timing is same as on 93 and was optimized for 93 you are missing out on power
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    13,614
    Post your tune and logs so we can see what is going on.
    The timing you can add is really one of those "it depends" type of things, maybe 2 degrees, maybe 4 degrees. The commanded fueling should be leaner on E85 though.
    May 2020
    16
    I did some adjustments on it, I did retard the timing for the E85, took it for a ride and it does run smoother. I don't want to do much until I get my Wideband in.
    Dec 2019
    48
    Couple things I noticed in your tune,
    Your Stoich AFR table is not setup correctly for running a flex sensor, and your Driver Demand tables are maxed out in the top 2 rows?
    May 2020
    16
    I am not sure I understand.... the Alcohol Composition % goes from 14 down to 8.9 at 100% ethanol.
    Dec 2018
    Dallas Texas
    35
    Check out how I did mine for reference GGGGGGGGGG.hpt
    May 2020
    16
    Ok so I see that the Stoich is off for 93 octane... but 14.7 is standard. I am lost on this calculation lmao
    Dec 2019
    DFW, TX
    124
    Quote Originally Posted by MartyB2017SS View Post
    14.7 is standard for E0 gasoline. E10 (pump gas) is around 14.1. Pure E85 is around 9.8. His table is correct
