Results 1 to 3 of 3
Thread: fuel gauge 2007 ford f150
    Jan 2009
    25
    put an extended range fuel tank in a 2007 ford f150. it has a whole 9gal more fuel capacity.
    installed the correct fuel pump for that tank as it would have been equipped for 2007.
    filled the tank and the fuel gauge reads only to 3/4 tank.
    i know with gm tunes, you can adjust the computer so it knows what the sender should read and what the fuel tank capacity is. i dont see that here.
    any way of getting that enabled?wayne's 07 f150 7-31-19.hpt
    May 2023
    im having the same problem same everything did you ever figure this out. just so happens to be the guy that owned the truck name is wayne. i shit you not.
    Oct 2016
    Poland
    2,038
    This is done in IPC (instrument panel cluster) with ForScan for example. Did that multiple times in variety of Fords. Part of as build data.
