![Quote](images/misc/quote_icon.png)
Originally Posted by
KDS
I'm running an lq4 with 243s and a moderate cam and cable TB. Looks to me like your VE values are way too high. I would scale the whole table back by at least 20 - 25 % and try that. Where did you get the tune from? If you took a tune from a smaller displacement LS and increased the engine size and cylinder volume that will scale up the VE values, maybe that's the problem. Looking at the log it looks like you can keep it going after the start with the throttle but it dies when you let off. I'd say its too rich. Your wide band should indicate this, are you logging it.
