Results 1 to 9 of 9
Thread: unsupported interface?
    Jul 2020
    Hello, I am trying to read the factory calibration using VCM suit(beta) and keep getting "unsupported interface". I am using a RTD flash tool supplied with my magnuson supercharger kit which is for a 2015 Camaro SS. I have followed all instructions up until this point and cant seem to get past this issue. Just curious if anyone else has had a similar issue? Any help is greatly appreciated.
    28,313
    You need to use the RTD flasher software with the RTD interface.
    VCM suite is for MPVI owners.
    Advanced Tuner 96gt4.6's Avatar
    Aug 2008
    Kansas
    489
    Bill has it. The RTD is a stripped down version of the normal MPVI, and does not work the same.
    You will need to buy a normal MPVI interface to read/alter your Camaro's Magnuson tune, as long is they did not lock the program. It all has to do with them being able to be SURE an emissions compliant tune is wrote onto the PCM and not altered before doing so.
    The Whipple kit I recently did came with an actual MPVI interface, and they simply slave out the MPVI interface serial so that you cannot open the tune they send you, only write it. But, after it has been written you can re-read and tune away as you wish.
    The Maggie car I did supplied me with the RTD tool you have, which pretty much leaves you with no choice but to buy an MPVI and then do as you wish.
    '17 Whipple'd S550
    Too many other projects to list.....see my YouTube channel for more: https://www.youtube.com/channel/UCr7...-XfDG53sCh6tcw
    Apr 2010
    45
    Quote Originally Posted by 96gt4.6 View Post
    I am getting the same unsupported interface and I have a MPVI-Pro. Used to read and write but quit after using beta. Now won't work with 4.6.3 either.
    2000 jeep jk with a jtec-+. Argh!!!!
    28,313
    Quote Originally Posted by jhertel View Post
    MPVI1 does not work on Jtec applications.
    Only MPVI2 supports Jtec.
    Apr 2010
    45
    Argh , I guess I will upgrade. Weird that I could read my ECU before so I thought the hardware was good to go. Sending in my old interface tomorrow.
    THX. Will miss the stand alone logging though.
    Mar 2009
    S. Florida
    583
    Got the RTD from Whipple and haven't used it. Can I use this to do a pro upgrade?
    Jul 2023
    4
    i have a 2004 KIA Sorento and it is saying unsupported.
    28,313
    Quote Originally Posted by lspwrd64 View Post
    Thats because the 2004 Kia Sorento is not a supported vehicle.
