Results 1 to 2 of 2
Thread: Does VATS delete work on a 3.5L with P12 PCM
    Jun 2020
    I'm doing an engine swap with a Chevy I5 3.5L into a Jeep. I'm using the P12 PCM. Does deleting VATS remove the need for a BCM to start the motor. If not, is there some way to work around it?
    Thanks!
    Tuner in Training DanN's Avatar
    Jul 2019
    Shuswap, BC, Canada
    38
    Well, I'm a pretty green noob myself, but I would think if your ECU is supported then yes, the VATS should do it. That is how I got my L61 running where it had no business being.
    I would go into the repository and download the tune file for your setup and make sure VATS is there. I can't imagine it not being there.
    1972 Triumph Spitfire Ecotec Swap:
    Stage 1: MEFI-4B & L61 - deceased; ate it's own balance shafts - because I did a dumb.
    Stage 2: E37 & GenII L61 - Ran great, but too meh.
    Stage 3: An LSJ is a good time in a 2000# car.
    2005 GMC Canyon base work truck.
    LS Swap, AR5 Trans, BCM transplant, Sierra Dash, G80
