The setup is on a 70 chevelle. 6.0 LSA blower 228 cam P01 ecm. When i come to a stop and stab the clutch the car wants to stall every time. RPM drops to 300-400 and usually recovers. Yesterday I tried adjusting throttle cracker and follower with no success. When i lift on the throttle both drip to 0. I also tried adding a clutch switch to blue pin 35 and grounded it when i hit the clutch. I was trying to get rolling idle to work. It did not. I am out of ideas and could use some help. VE table is not perfect yet, its close (10% rich or better) but i need to figure this out first. Thank you.
