A lot of you guys have requested more loggable parameters to help navigate where to make changes when tuning the 2017+ Ford 6.7 diesel, and the Ford Ranger (SID-209).
In the latest beta, I have added a few new channels for logging that will pinpoint which maps are in use.
Parameter 14590 - Base Operating Mode will tell you which of the Map # is in use.
Parameter 14589 - Injection Config for EOM will tell you which Config # is in use.
Parameter 14588 - Engine Operating Mode (EOM) will tell you which Mode # is in use.
Hope this helps.
