![Quote](images/misc/quote_icon.png)
Originally Posted by
smokeshow
If I had to guess, you are pedal to the floor before launch? Your driver demand pedal map ratio is clipping the pedal that gets input to the desired torque pedal map table. So it won't allow any more requested torque. Also, desired load is clipped because it isn't enriched so you will likely not get an improvement unless you enrich at lower pedal too. However as soon as you do this, popcorn, combustion stability limits, and thermal protection limits will likely follow very quickly, also impacting your launch.
Take it slow so as to not break anything, but you can slowly remove these limits as they come up.
