Results 1 to 6 of 6
Thread: negative ltft and positive stft after cam swap
    Jun 2018
    611
    Like the title says. Short terms are showing positive but the long terms are buried negative. I pulled some fuel out using ANN method and it runs worse. I'm guessing the ltft are wrong? Do I need to hook a wide band up here already? Just trying to get it running right before it hits the dyno. Could the o2s be trash? Q.CHARGER.002.hptq.001x2.hpl
    Mar 2009
    S. Florida
    583
    Quote Originally Posted by JASON11WS6 View Post
    Your tables don't match. bold must match in each table
    inj pulse width vs fuel mass and fuel mass vs inj pulse width. this one you open by clicking side, then paste in.
    Jun 2018
    611
    I'll try that again. Forgot about the inverse table.
    Jun 2018
    611
    I updated them and I'm still gettin the same issue
    That's a vct problem turn off nn and all vct tables to be able to make adjustments on your ve. Otherwise the vehicle will pull major timing because your cams moving and causing fuel swings. Or work with the new nn tuner up to you
    Jun 2018
    611
    I think we had one of the o2s switched around. It dialed right in after that. Now we need to fix the idle
