Results 1 to 20 of 20
Thread: Timing falls off the cliff in 7th - 2019 Mustang GT-A10
    Tuner barkingspud's Avatar
    Mar 2006
    NW Burbs of Chiraq
    119
    Folks,
    2019 A10. Vortech, E85 Return Fuel System, Catless LT's, Stock Converter and Trans. At the track yesterday trying to get her dialed in.
    Attached log/tune the car ran a 9.96 but as you will see in the log, once the car shifts in to 7th the timing goes from 20* down to 0. There is no KR. I thought is was due to the Driver Demand Torque Table but apparently, not. Traction Control and Advance Track were switched off via the switch in the car.
    Would someone mind having a look see? I'm baffled.
    Thanks in advance,
    Mark
    9.96 Run 9-4-20.hpl
    Mark_Lewis v4 - 9.96 run.hpt
    Feb 2016
    482
    fix fueling off --- your getting a in gear limit
    is that a vortech OS/tune?
    your lean the whole run on fuel trims like paul pointed out.
    i must be missing something but how can ETC be half of what is built into the DD table?? the tq ratio is sub .60 the whole run and finally hits 1.0 once timing is yanked.
    OP you might consider cleaning up the channel log, several duplicates and it helps for the visual to group similar items, fuel/timing/tq etc. also it has been said that the SAE channels are slower than non SAE channels. try swapping the SAE to non SAE.
    Advanced Tuner LastPlace's Avatar
    Jul 2016
    613
    I agree you need to clean up your config file and please add any pids that have "limit" in them
    try this
    Mark_Lewis v4 - 9.96 run-2 - test this.hpt
    Mar 2006
    NW Burbs of Chiraq
    119
    Thanks for the insight guys! This is a custom tune. I will review/test and report back! My next track days are Sept 11th, 12th and 13th so, we will see how she responds.
    Mar 2006
    NW Burbs of Chiraq
    119
    I've been messing with the PID layout a bit. Haven't actually used it yet but what do y'all think?
    2018+Coyote New.Channels.xml
    Jul 2016
    613
    Jul 2016
    613
    Where is your IAT sensor located and which PID is it reading to "iat"?
    Mar 2006
    NW Burbs of Chiraq
    119
    Quote Originally Posted by LastPlace View Post
    IAT is on the boost side of the intercooler. Uses the PID I have in the channel config.
    Mar 2006
    NW Burbs of Chiraq
    119
    Looks good man! I tend to put everything including the kitchen sink in but less is more. Thanks.
    Tuner in Training that_na_coupe's Avatar
    Feb 2016
    Houston
    19
    Did you end up finding the issue? I'm seeing something very similar on a procharged gen 3 F150. Timing falls on it's face in 5th gear and ramps up very similarly to whats going on in your log.
    Jul 2016
    613
    Quote Originally Posted by that_na_coupe View Post
    Best to start a thread, post your file and your log
    Mar 2006
    NW Burbs of Chiraq
    119
    Nope. What we do see is the Desired Load is 1.3 but the Actual Air Load is 1.6-1.8 so, Torque Management is trying to match Desired Load. It's a beast.
    Jul 2016
    613
    Quote Originally Posted by barkingspud View Post
    Did you run another log with that test file?
    Mar 2006
    NW Burbs of Chiraq
    119
    We have been over several revisions and are getting close. Based on the load characteristics , injector size (ID1300's) and other parameters, We've come to the conclusion that Torque Management on these cars is a nightmare. LOL. Appreciate everyone's input. Hoping to get this sorted out before the end of the season.
    Jul 2016
    613
    If it is Torque management that's doing it, it will show up as that with one of the "source" "Limit" or "TR" pids.
    Aug 2010
    Detroit, MI
    982
    Looks like a request from the trans. What source though, not clear. Make sure to monitor any torque requests coming from the trans.
    Mar 2006
    NW Burbs of Chiraq
    119
    Yea. We are going through the tables. We have the 6-7 issue pretty much licked but now running in to it with the 2-3, 3-4 shift. All called from Torque Control on the Timing and Throttle Source. Making progress though!
    Jul 2016
    613
    Which tables are you guys adjusting?
    Jan 2017
    48
    Are you pulling the fuse or plug for the traction control.
