Results 1 to 7 of 7
Thread: Can VVT on 2011 Cadillac SRX 3.0 be turned off?
    Aug 2020
    4
    Hey guys, I was wondering if anyone has shut the VVT off on a 2011 SRX 3.0?
    If so what did you need to do? Thanks for any help.
    Advanced Tuner ZeroBoostBuick's Avatar
    Aug 2008
    S.W. Ontario Canada
    321
    Generally speaking... Unlike the DoD (Displacement on Demand), the VVT can't be Shut Off per say. But you can tune it to stop varying the cam timing by setting the cam timing to the same degrees in all areas/tables.
    What the best compromise for the intake and exhaust cam timing could be I have no idea.
    If Possible, can you post your tune if you have it ?
    Aug 2016
    384
    With all due respect, why on earth would you want to "shut the VVT off" on this engine? VVT allows these small displacement V6s to have reasonable torque at lower RPM and good horsepower at high RPM?
    In any event, if you want to prevent the cams from phasing away from their mechanical position, set all the cam phase tables to 0*.
    Aug 2020
    4
    Quote Originally Posted by tunerpro View Post
    A friend of mine wants to try playing with cam angles and try shutting it off.
    I thought I would ask here first. thanks for your answer.
    Aug 2020
    4
    Here is factory tune.
    Aug 2008
    S.W. Ontario Canada
    321
    Quote Originally Posted by HotrodZ28 View Post
    Thanks mate... Appreciate it.
    Aug 2008
    S.W. Ontario Canada
    321
    Yeah, you can set all the cam timing tables anywhere from 0 to 32 degrees. But I've not seen a factory tune where it's higher than 24 or 25*... I think the VV timing has a hard physical stop that won't let you set it anywhere it could kiss the pistons, but I could be wrong. But as long as you stay withing 25* you will not have any issues.
