Hey smokeshow, thanks so much for sharing this tip. It has helped me out heaps and I use it all the time. I had to modify your parameter slightly to suit my setup i.e. LTFT + STFT and WB EQ ratio error.
I am using manifold air temp sensor.
I have had the calculator out a number of times for sanity checks comparing the math result with the the expected result. For testing I tried the following in your formula:
- VVE air flow PID (g/s) -not ideal as it maxes out at 512g/s
- VVE PID (mg*K/MPa)
- + all of the above with LTFT + STFT and WB EQ Ratio Error
All methods came out near smack on.
Well done, and thanks so much once again
