Results 21 to 40 of 51
Thread: AUDI/VW (2.0T)- Stock/Tuned Files (Repository)
    Dec 2018
    46
    Quote Originally Posted by LAGP View Post
    Yes of course.
    ECU MED 17.1 SW 8J0907115BD_0010
    Audi TT 2012 2.0T EA888 gen 2 k03 turbo, DSG DQ250
    Same ECU as you but I'm running an EFR7163 and larger injectors (the original should also be viewable in the revision history).
    AudiTT_latest_with_transmission.hpt
    To provide a bit more tune-relevant info about the build:
    - The block has been overbored to 83mm
    - ZZPerformance Opel LNF injectors
    - Integrated Engineering 2.0T intake manifold (with runner flap delete)
    - AEM MAP sensor (30-2130-50) in the intake manifold
    - Bosch 4-bar MAP sensor (03K906051) in the pre-throttle inlet
    - 2-stage oil pump set to permanent high-pressure mode in software
    - AC system has been removed, so associated pressure checks, codes, and fan control failsafes removed
    - Other stuff I might be forgetting...
    I'll also attach my .xdf definition files that have some custom parameters including the KFLBTS ones for fueling. I sent these to Steven a while back to see if he could add them for everyone, but I don't think he's gotten around to it yet. As such, if you purchase the user-defined parameters feature you might be able to use them directly if your ECU binary has everything in the same place as mine.
    ECU definitions: AudiTT_8J_latest.xdf
    DQ250 definitions: transmission.xdf
    Jul 2020
    49
    Great info very helpful, I am curious to know how do you found out that those parameters were available to define? I already summitted a ticket to HPT asking to add the new parameters, here is a list of them:
    SOURCE FILE: AudiTT_8J_latest.txt
    SOURCE DEFINITION: AudiTT_8J_latest.xdf
    TABLE: Substitute value for CAN error
    SCALAR: Maximum speed 0.0000
    TABLE: Fuel Correction HSP
    TABLE: Correction Fuel Supply
    TABLE: Minimum ignition angle efficiency with minimum filling
    TABLE: Nominal filling characteristic map
    TABLE: Optimal engine torque
    TABLE: Threshold compressor pressure ratio for LDR recirculation valve control
    TABLE: Offset printing ASR intervention
    TABLE: Maximum filling LDR (Variant 0)
    TABLE: Maximum filling LDR (Variant 1)
    TABLE: Maximum filling LDR dependent on LDK (Variant 0)
    TABLE: Maximum filling LDR dependent on LDK (Variant 1)
    TABLE: Maximum filling LDR during knock (Variant 0)
    TABLE: Maximum filling LDR during knock (Variant 1)
    TABLE: Inverse Wastegate Flow Chart for AVS operation with small valve lift
    SCALAR: Maximum pressure difference across turbine 0.0000 hPa
    TABLE: Acceleration limiter
    TABLE: Offset for torque comparison
    TABLE: Maximum torque at clutch
    SCALAR: Maximum speed AWD 0.0000
    SCALAR: Minimum speed threshold AWD 0.0000
    SCALAR: Maximum engine torque 0.000
    SCALAR: Config Torque Calculation 0.00
    SCALAR: Inlet MAP Slope 0.0000 hPa/V
    SCALAR: Inlet MAP Offset 0.0000 hPa
    SCALAR: Oil pump high pressure threshold 0.000
    SCALAR: Max Engine Temp OilPCtl -273.1
    SCALAR: Max Oil Temp OilPCtl -273.1
    SCALAR: Max Oil Temp OilPCtl ShortTrip -273.1
    SCALAR: Min Oil Temp OilPCtl -273.1
    SCALAR: Min Oil Temp OilPCtl ShortTrip -273.1
    FLAG: Disable DFC_TMPnpl_C Not Set
    FLAG: Disable DFC_TMEnpl_C Not Set
    FLAG: Cooling Plaus High Side Check Not Set
    FLAG: Cooling Plaus Low Side Check Not Set
    FLAG: Cooling Plaus Stuck Check Not Set
    FLAG: LBKFGS Codeword Not Set
    FLAG: LBK Codeword Not Set
    FLAG: LBKABG Codeword Not Set
    FLAG: CWDCTCW Not Set
    SCALAR: CWKONCCSEN 00
    SCALAR: CWKONCCTKA 00
    SCALAR: CWKON3TCC 00
    TABLE: KLPBR
    TABLE: KLTIKRPR
    TABLE: KLTVTSV
    TABLE: KFLANS
    TABLE: KFKHFM
    TABLE: KFKHFMUG
    FLAG: BoostCtldiag_stCod_C_VW Not Set
    TABLE: Eng_nMinTrbOpm_T_VW
    TABLE: BoostCtl_pDeviThdMaxSetBas_T_VW
    SCALAR: PSRMN 0.0000
    SCALAR: PSRMX 0.0000
    SCALAR: UADPSRMN 0.000000
    SCALAR: UADPSRMX 0.000000
    TABLE: KFLBTS
    TABLE: KFLBTSLBKO
    TABLE: KFLBTSLBVS
    TABLE: KFLBTSVS
    SCALAR: I15031_PID4FD_C 0.00
    Dec 2018
    46
    Should probably create a separate thread if you want to discuss further, but I purchased a super map pack for my ECU and was tuning with a hex editor + WinOLS. Was a total pain because I could only bench flash. Once HPTuners started getting into the MED17.1 world I reached out to them and sent them what I had. They were kind enough to work with me to add support, so now I don't have to bench flash anymore (yay!).
    I've sent Steven my definitions before and he went through and added most of the ones that made sense. There are some weird parameters in here that don't make sense for HPT to add. Some of them are things that I was just playing around/learning with and some are things that most users will never need to touch. I think the BoostCtl, KFLBTS*, and many of the AVS-related table variants are probably the main ones that HPT should add.
    May 2014
    USA
    457
    How long did it take to get the tables/params added? I have a decent xdf going for my simos18 and requested some tables to be added but no updates or feedback at all.
    Dec 2018
    46
    It varied. When I requested some of the main tables that were missing, like KFMIRL and KFMIOP, then it only took a couple days for them to respond and update VCM Editor. For some more obscure parameters, they either took a week or two or just never responded about adding them. I'm sure they're busy and these things are fairly low priority, especially considering people that really need them could just buy the user-defined parameters feature.
  6. #26
    May 2014
    USA
    457
    Yeah, fair enough. For the Simos18 stuff, it seems to be OK for a basic bolt on car, but nothing really beyond that yet. Even with the user defined tables, the scanner is still missing some very key parameters. For example, can't even log wastegate "duty cycle" or any of the axis' that go into the set point tables. Hopeful they will get that added sooner rather than later.
  7. #27
    Quote Originally Posted by aaronc7 View Post
    they added wg duty cycle for med 17 in a couple weeks after putting in ticket
  8. #28
    May 2014
    USA
    457
    Quote Originally Posted by bb-tt View Post
    Still nada here. A little disappointing, it's pretty much common knowledge info for the PID info. I can log WG on my phone over generic BT dongle but not HPT...
  9. #29
    I should have been more specific they added it to the scanner along with boost and something else I cant recall after a couple weeks for my b8 ecu 8K2907115AG_0002. Kind of hard to log without boost and wg duty cycle. I would think it is not that difficult to add the pids in once they have been identified(easy to do block map with vcds) but i am not a sw engineer so maybe Mukhery can shed some light on how difficult it is.
    Quote Originally Posted by mukhery View Post
    That's not the point though, it was sold as ready to tune but stuff that is readily available for simos and other ecus is still missing in med 17 definitions. Asked for KFPED and KFURL in like August and have heard nothing.
  10. #30
    May 2014
    USA
    457
    The missing wastegate PID for logging is on SIMOS here--I guess I should have been more specific too. Several key things missing from the logger. I have my own spreadsheet with around 50 more PIDs on it that I sent in, hopefully it gets added soon. I haven't messed with MED17 stuff, but tables/PIDs seem spotty all around for all of us. I suppose it's still "beta" to a certain extent. Hopefully it will continue to improve. A lot of potential here- I have defined many tables myself using user defined maps, but the scanner I cannot define my own stuff sadly. That's the big hurdle holding me back right now.
  11. #31
    Sep 2012
    Just started with HPTuners.
    Tuned my 2018 Golf Alltrack with Eurodyne and decided to try HPT for the GTI.
    Still trying to find the right tables but learning.
    Here is the OEM 2015 GTI non PP file
  12. #32
    Jun 2019
    Any one have a Mark V tune for a 2006 GTI DSG trans.
    I know the trans isn't compatible with HP Tuners. But I would still like to tune the motor.👍
  13. #33
    May 2014
    USA
    457
    Might be an obvious question, but have you tried getting a virtual read with the MPVI2? You'll need a virtual read from the actual car as each file is associated with a specific VIN/controller serial etc.
  14. #34
    Oct 2019
    CT
    34
    how did you read the 07 A4? when i tired it said it couldnt define it.
  15. #35
    Tuner SuperG5's Avatar
    May 2021
    Mars
    50
    Do you have any tunes to compare for the 2015 a4 2.0 tfsi? I have the stock file just dont know where to start tuning it
  16. #36
    Sep 2019
    ON, Canada
    346
    Quote Originally Posted by SuperG5 View Post
    If you start your own thread with stock file, tuned file and logs of the tune so far I will be able to assist you better
  17. #37
    Tuner in Training lumberjackzac's Avatar
    Jun 2021
    Las Vegas
    10
  18. #38
    Jun 2021
    Las Vegas
    10
    Corn bookcase DSG
    corn_Sport_DSG.hpt
    corn_OEM_DSG.hpt
  19. #39
    Apr 2022
    London
    7
  20. #40
    May 2021
    Mars
    50
    Ok Ill Start A thread , I also have a simple tune I played with. I don't mind adding
    Quote Originally Posted by TylerJDubbs View Post
