Results 1 to 20 of 22
Thread: LM1 Calibration
    Advanced Tuner INTHERED's Avatar
    Marriottsville Maryland
    203
    LM1 Calibration
    I have read a few threads be none of them seem to completely cover the topic of setting up the LM1 with the Hptuner Pro EIO. Check this out:
    Right now I have my LM1 Analog Output 2 signal wired to EIO pin 1 and the Analog Output 2 ground wired to EIO pin 5 using a shielded cable and a 1/8 inch stereo plug from Radio Shack. The Ground is connected to the shield and the signal is the center conductor.
    Using the LM1 software I programmed my LM1 Analog Output 2 for a 0v-5v swing where 0v is set to an A/F ratio of 10 and 5v is set to an A/F ratio of 20. Under the advanced tab I set the LM1 sampling rate to 1/6 of a second. In the Hptuner scanner I inserted the LM1 PID from the AUX list into the EIO input 1 cell.
    Is this the correct way to setup the LM1 and the HPtuner Scanner for datalogging accurate A/F ratios ?
    Thanks >>>>> INTHERED
    LINGENFELTER MAGNACHARGED 2000 A4 Torch Red Z51 Vert, Smoothline HT, LPE IC Magnacharger, Z06 cam, LPE CNC heads, CC RPM kit, LPE hood, Yank 2800, Rossler trans, Z06 rear w/300Ms, Chrome C6 Z06 rims w/PS2s, Z06 calipers w/PF carbon metallics , Eradispeeds, WCC screens, BBK 80mm TB, TB bypass, 160 TS, GM Z06 MAF, Blackwing, Corsa Pace, AR headers X-pipe & Hiflow Cats, GM HP wires, NGK TR6s, Hptuned by INTHERED with a best 1/4 mile of 10.87 @ 128.90 mph on BFG DRs
    Apr 2006
    Twin Cities, MN
    139
    i thought LM1 went directly into a computer for logging via LogWorks... no?
    28,318
    sounds about right to me.
    May 2006
    Upstate NY
    207
    Quote Originally Posted by INTHERED
    What is the standard output that HPTuners has programmed for the LM1? I don't think it is 10 to 20 is it? If not you'll have to custome make an input to match how you've programmed the LM1.
    Tim
    28,318
    yeah its 10-20
    May 2006
    Upstate NY
    207
    Quote Originally Posted by foff667
    yeah its 10-20
    Yeah, I looked it up and found that out. Only it's 10-20 in a voltage range of 1.0-2.0 volts.
    Tim
    GM World Class Technician
    ASE Master Auto Technician
    L1 Certification
    2001 Silverado 6.0L Swap
    28,318
    Quote Originally Posted by bullygoat
    Tim
    um no, that would only give you a range of a/f between 12.0:1 & 14.0:1
    10-20 & 0-5
    the LM-1 predefined config is Wide Band O2 - LM1: result = volts / .5 + 10
    5v/.5=10 + 10=20 afr@5v
    203
    um no, that would only give you a range of a/f between 12.0:1 & 14.0:1 10-20 & 0-5 the LM-1 predefined config is Wide Band O2 - LM1: result = volts / .5 + 10
    This is what makes the forum so fun.
    My LM1 A/F readings and the Hptuner LM1 readings differ by .2 to .5 is there an easy way to get everything to match up ?
    May 2006
    Upstate NY
    207
    10-20 & 0-5
    Just checking because the manual for the LM1 that comes with logworks says it's setup for a 1v-2v range. Didn't want the original poster to run into problems with incorrect readings.
    Tim
    28,318
    yeah when you get it out of the box i believe thats how its setup...you need to change some of the stuff in logworks to get it "calibrated" correctly so its a 0-5v output.
    203
    I have the LM1 Analog Output 2 programmed for 0 to 5 volts but the Hptuner log sez the LM1 is reading 14.95 while the LM1 log sez its reading 14.7 so I have a difference of .25 A/F. So I was thinking of setting 0 volts to a 9.75 A/F ratio and 5 volts to a 19.75 A/F ratio on Analog Output 2 so that it would shift everything down by .25 A/F. Does this sound reasonable ?
    INTHERED
    May 2006
    Upstate NY
    207
    If you have a steady .25:1 error, then yes. Mine has an offset of about .1V so I had to change my equation for my LC1 accordingly.
    Tim
    L1 Certification
    South Florida
    44
    INTHERED
    What ive done is I have made a custom PID in HPT. The default LM1 formula is V/.5 +10. So if you are off .2 or .3 then try something like v/.5 + 9.7 or 10.3. Then check to see if it matches.
    Sep 2006
    203
    can some one tell me whats to do, i have the LM-1 and i set it to sample 1/6 rate. it's connected with the red wire to #1 and the braided shield wire to #5 and the white not used, it's plugged into my mpvi pro. i got the histo set up i believe and working, but the afr is way off, commanded will be 14.6 the wide band shows 14.7 but the histo shows 10. to 12. so it's reading way rich. is something wrong or do i have to adjust something??? seems my wideband is way off.
    Sep 2006
    203
    anyone?
    Sep 2006
    203
    common i am sure that there is some with a LM-1 that had this happen, i am not sure how to adjust to get them matched
    28,318
    can you post a scan log for us popeye?
    Nov 2005
    Someplace high in the Himalayas
    770
    I created a custom pid. Then set the LM-1 to 0-5v, 10-18 AFR. In HPT, set the PID to volts/.625 + 9.68(or your offset).
    www.outlawpontiacdragseries.com
    Come race with us in MA, PA, and VA!
    2005 GTO A4 - Spintech X-pipe with Powerstick mufflers, IAT relocate, Volant, !scoops, !cowlgasket, !skid plate, LM-1, HPT2.0/MPVI Pro USB, 275x40x17 Nitto DR, rolled fenders, Pedders 2985 springs, Britax baby seat with 5 point harness.
    Stock:13.36@104
    Mods in sig:[email protected]
    203
    Quote Originally Posted by popeye55
    anyone?
    Did you program the LM1 Analog 2 output for 0 volts = 10 A/F and 5 volts = 20 A/F ?
    Nov 2005
    770
    First off, make sure you do a Free air calibration.
    0v = 10 afr
    5v = 18 afr
    Set the LM-1 in logworks to 2.5 = 10afr and 2.5v = 18 afr. MAKE SURE AFTER YOU PROGRAM THE LM-1 YOU POWER IT COMPLETELY OFF. Then setup a custom pid in hpt. Set it to volts/.625 + 10(10 for now). Set the decimal places on the AFR histogram to 3 decimal places. Goto the scanner and open the pid and go to configure. Leave the window open so you can change the numbers. If you close it and start the scanner, it won't let you go to user config for some reason. Then start the scanner, it should be around 14.000. If it isn't, start moving the "10" up and down. Stop the scanner, then restart it so you get an accurate average. You can make changes and see it change right away, but it won't be accurate because its averaging in the previous values. Hope that makes sense. Anyway, you just found the offset. Go back into LMProgrammer and set it to 0v = 10 and 5v = 18, THEN TURN THE POWER OFF ON IT AFTER YOU PROGRAM IT. Go for a drive in closed loop and see if your around 14.6-14.8 all the time. You could set the PE AFR to 12.0 across the board and see if it goes to that number when you mash it.
    I do have a few questions myself for everyone; if you set it up this way, will the AFR near the upper and lower limits be innacurate away from the middle 14.7? Has anyone figured out the 50 points to put in the make a curve instead of a straight line?
    Stock:13.36@104
