Results 1 to 19 of 19
Thread: 2020+ Neural Network VE tuning on Silverado 1500 6.2
    Nov 2019
    3
    Hi,
    I have just started tuning the neural network tuning system on the 2020 silverado 6.2. I have a supercharger with water to air intercooling fitted to otherwise stock internals.
    Issues so far:
    The 2020 silverado has a LIN BUS enabled MAF sensor. Barometric pressure, Intake air temp and probably a few other things are sent via LIN Bus to the ECM, the old "swap the intake temp sensor to the LT4 style MAP+Temp sensor" doesn't work. I have had some success modifying the manifold air temp model to bias more towards coolant but obviously depending on the level of heat soak in the intercooling system this doesn't read actual intake temp which confuses the model a bit. Anyone found a better solution for this? Is it possible to wire in the factory sensors to the E90 to enable SCIAP and temperature?
    Having said that the stock cal holds together really well. I did have to re-tune the MAF curve at the top end (using stock airbox and MAF) as we are near the end of the range of the standard sensor and obviously the spark and fueling to get knock and EGT's under control but that was straightforward.
    As far as VE tuning goes I have stock parameters which are "Volumetric Efficiency Aifrlow" and "Mass Airflow (Sensor)" I can just compare these two, because I know the MAF is good (comparing steady state LTFT+STFT and Widebands) so if I now tune the VE airflow to match the MAF airflow I should be right? Is this the method others are using? I don't see that I need to fault out the MAF etc and tune open loop as the older Gen4 system if I have these variables.
    Also the neural network is pretty tricky. I just want to target the high load mid rpm VE range which is overpredicting, most of the VE airflow looks good, but it re-calculates the whole curve coefficients so I am always changing the whole map. Each time I spin the online calculator the numbers change a bit even with the same inputs so it's tricky to know if I am fixing my problem or causing more problems in other areas. The load axis is also just marked "Load" with 0-1. I changed this to 1.5 because I am roughly putting in 50% more air, but does anyone know what parameter is acutally used to calculate "load" is it cylinder air? Likewise with intake cam position, it appears to be referenced to something other than "degrees of advance."
    It would be great if HP tuners had some method of predicting airflow from these tables or some sort of compare function.
    Anyway if anyone else is having success using the neural network tuner on GM engines I would love to hear your thoughts.
    Advanced Tuner Redline MS's Avatar
    Jun 2006
    New York- South Florida
    536
    The load axis is in grams/cylinder. Also use (2321) for the load and (2172) for cam angle...
    Full Service GM Late Model Performance Facility
    www.redline-motorsports.net
    Follow US on FACEBOOK!
    Follow us on Instagram! redline_motorsports
    Do this mean that GM made a neural network for the 2020+ ecms like dodge now,?
    Apr 2007
    330
    Is this "neural network" thing just a fancy marketing term for some kind of automated VE tuning or something?
    Mar 2010
    Texas Hill Country
    3,299
    Quote Originally Posted by cmitchell17 View Post
    no, its a different logic altogether. dodge has been using it for years.
    Apr 2007
    330
    I just don't get how it applies to engine controllers? I guess engine controllers could do better if they "learned", but I would think that this would require a lot more memory than the 2MB or whatever the flash has.
    May 2003
    South FL
    1,395
    [email protected]
    Owner/GM Calibrator
    Training a neural network is a resource intensive task. Running a neural network, not so much. The ECU's can run the neural network, but they can't adapt to changes made to the engine. That's why tuners need to retrain the neural network after engine modifications are made.
    Apr 2007
    330
    I see there is an option for the T87A? I just think theres no way the T87A has this neural network thing given how crappy the T87 and 8L90 shifts haha
    The neural network is used to estimate Volumetric Efficiency in some Dodge and GM PCMs. As far as I know, their TCMs don't use neural networks.
    Jun 2006
    536
    Victor....where is HPT referencing the camshaft angle values from in the trainer? They seem like arbitrary numbers and are not like prior camshaft angles which started at 0 degrees and retarded the camshaft from there...
    Quote Originally Posted by Redline MS View Post
    I asked one of our engineers who specialize in GM tuning about this. Will post an update once I get a reply from him.
    We added 2 new parameters with the latest VCM Suite Beta(4.9.389). "2077 - Intake Cam Angle from Open Position" and "2078 - Exhaust Cam Angle from Open Position". PID 2077 should have the same value as the "Intake Cam Angle" input to the neural network.
    sometimes i feel like GM's cars are being designed by ex-NASA scientist
    May 2021
    12
    I've seen a few places where it was referenced that the load axis is PID 2321 Cyl Airmass... but when I pulled the table, I'm showing Pressure Ratio in the row axis. RPM is still the column axis. I was planning on using PressureRatio (Manifold Pressure / Baro), which is already a predefined math... but figured I'd check now to avoid chasing my tail later.
    Has anyone had success with NN editing? I am making just a global 15 and it does nothing anywhere to fuel trims
    Aug 2009
    Calibrating
    3,378
    Just did a 2020 cam truck for a dealership 2 weeks ago.. spent about 5 hours on it with NN updating (about 8 updates to mail it) fuel trims fairly tight and been doing good.. still may be missing some pieces to the puzzle but they can be tuned fairly good
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Man it?s not liking any of it. He put a cam in it, and it?s running about 15 rich. Tried globally pulling 15 and adding just to see if it made a difference, nothing. I even messed with injector flow rate and nothing. Only hacking the maf made a difference, and I really didn?t want to do that.
    Aug 2009
    Calibrating
    3,378
    I posted in your other thread… don’t hack a tune, leave IFR alone. Tuning a MAF system is needed on almost any modded vehicle so that’s acceptable
    14 Gen 5 Viper
