11 challenger, fully forged, procharger, midrange cam with phase limiter, nothing crazy.
lots and lots of these have been done.
for me this is first one with demon tb and it's the only thing i can see different from others i've done.
i look at airflow tables, diagnostic tables, the trans limit tables and i can't find anything different about this file but i'm getting an extremely consistent throttle cut at 4500. dyno or street.
i'd appreciate any help. i've moved all kinds of tables every which way and it's always there. starts, idles, drives fine. just this wot cut. and no code or flashing bolt in the dash either after it happens.
thanks
only big change i see is you put neural network back on.
changing fan speeds and speed limiter and some afr couldn't possibly close the throttle.
and i've done lots without NN, but i'll give it a try.
i can't see what codes you changed in compare mode. what did you change there?
35573, 2102, 44281, 44280, 2088, 34082, 44442, 44448, 44451, 34230, 44453, 444390, Fans and limiter speed. Your temperatures are low. Do not interfere with the engine))). Especially if the catalyst is installed
Nevertheless, I do not recommend lowering temperatures. The most extreme is low 95, medium 97, high 99.
Why is nothing done in the program to work without catalysts?
