Results 1 to 20 of 32
Thread: Which table? GEN6 CAMARO
    Anyone know which table is responsible for the Rain/Snow mode? Reason I ask, at 900hp traction is an issue and I wanted to see how that mode compares to normal mode. Not sure if it's a timing table and/or torque table, but if the settings aren't too much lower it might be worth it depending on temps and tires.
    Sep 2020
    should be in Engine->Tq management->Driver Demand->map B-Winter/4wd. tour and sport are map A and track is map C
    Aug 2014
    Central, LA
    737
    Most of the stuff doing the work is in the bcm, but you can log accelerator mode and find out. Depending on what year it will be either map b or c.
    Nov 2009
    All Around
    3,149
    you can try to manipulate the throttle with driver demand maps
    Thanks for the replies
    I am guessing it is Table B. When I went back and looked at the stock tune A and C were the same, but B was different.
    there is a map which is not accessible with hpt, which assignes the DD maps to the modes. most likely winter and normal mode share the same map.
    can you make a screenshot of xour calibration details and i will check it
    May 2003
    South FL
    1,406
    I've seen some cars where Winter/4WD is actually used for Track Mode.
    [email protected]
    Owner/GM Calibrator
    Aug 2014
    Central, LA
    737
    Quote Originally Posted by dertobi View Post
    I'm not surprised. You have access to lots of stuff we all want lol
    Here are the Stock tables
    Attachment 106395
    Quote Originally Posted by benf View Post
    Attachment 106395
    that's not what i need, click on "edit" > "calibration details" and do a screenshot.
    if you did, and put into the attachment link... cant open it, says link invalid
    Ok, I will do it tonight when I get home. Thanks. Weird the attachment is visible on my end... Anyhow, will redo what u need tonight.
    What are you using to view maps not accessible with hpt?
    Here is the Cal Details screenshot:
    Sep 2011
    Germany
    197
    Quote Originally Posted by 32vape View Post
    WinOLS
    Does winOLS have definitions for e92 ecu's, or you just have to be able to define tables yourself out of the hex?
    i havent seen thid OS yet, but the description tells it's a ZL1 right... so
    normal/sport/eco = Map A
    Track = Map B
    Winter = Map C
    WinOls is more or less just a very good hexeditor you have to find all the definitions yourself
    Track = Map B
    Winter = Map C
    Thats interesting, cause when i look at the stock tune, MAPs A and C have the same tune, but B was less. I would think B would be the Winter/Rain tune??
    May 2003
    South FL
    1,406
    Look at the throttle progression when you're always above 50% throttle and 4000 RPM. B mode is actually track mode for most Camaro and Corvettes. The labels are not correct. I just tuned a 2017 ZL1 the other day and had to adjust the B table as the owner wanted more throttle response in track.
    [email protected]
    Owner/GM Calibrator
    I looked at 2 other 2017 zl1 stock tunes and both showed A and C higher than B(winter)
    Could there be a difference in auto vs M6? Mine is auto.
    no there is no difference between AT and MT.
    GM mostly has the less responsive pedal in Track mode for better control, same on my ATS-V for example.
    On my V I allocated map C to winter mode, as C wasn't used stock and even reduced throttle progression and max power request for snowy conditions
    there is a nother table which chooses to sustain the used mode over ignition cycle, in most stock file this is only active for sport and tour mode,but not for track or winter, so you always have to choose it again when restarting the car
    fixed that on my V too, nice gimmick
