So I've been playing with my tune some, seems like I have the VE table close (maybe not this is my first time ever attempting any tuning) and worked on the MAF some, when I put it into MAF only though it huts at idle a lot!
My question is though, when it is put back so everything is functioning, when you put the car in gear it idles up. if you drive it will actually idle up enough to shift gears. not too bad in RPM according to the log attached. any ideas on where to go?
thank you for the help!camaro diag 3.hplCamaro 6.0 4l80e VATS-EMMISIONS delete flex fuel injectors.hpt
