10r80 Select Shift
Wondering if anyone has gotten the 10r80s to work like a few of the other transmissions, in regards to the paddles. What I am trying to achieve is to use the paddles to get the car to a certain gear..... then go WOT and have it auto shift up from there. I have built tunes for other applications and made this work, however this 10r80 is kicking my rear on this one. I thought it would use the (select shift WOT) under shift scheduling tab. I have tried to input lower than desired OSS numbers equating to about 6k engine rpms with still not results. This table comes stock set to 60,000 so I thought I had figured it out but still no luck.
Thanks in advance for any input.
Adam
6512 and 21567 im pretty sure
Did you guys figure this out? I'm trying to do exactly this.
You have to set the desired WOT shift OSS very low and it will work.
