Hi all,
Just wondering if anyone has come across the correct parameter(s)/table(s) to set the desired idle speed when in lowrange with D/R selected?
In high range (2wd or 4wd) the desired idle speed in D/R is 680rpm (or 650rpm in low idle mode). This can be easily set via the various tables and parameters that are currently accessible through HP tuners.
However, once low range is selected the desired/commanded idle speed gets bumped up to 784rpm in D/R. Furthermore, the desired/commanded idle speed gets bumped up even more to 900rpm when the vehicle is slowly rolling (4-5kph). The rolling/moving table idle speed table [ECM] 34305 does not set the idle speed when in lowrange, only high range.
This all becomes quite an issue with extremely low gearing (transfer/diffs) as the bump in idle speed causes the vehicle to try and drive over the brakes. Not particularly what you want when you are about to descend a rather large ledge.
Anyone else experience this or have any ideas?
