Results 1 to 14 of 14
Thread: AEM 30-0334 help
    Jan 2021
    East Coast
    6
    AEM 30-0334 help
    I just wired in my AEM 30-0334 x series wideband it works as far as reading a/f ratio but when I try to data log in hp tuners it has a red circle with a slash on a key I take it as its locked out for some reason did some searching on the forum and not having any luck vehicle is a 2013 Camaro zl1 e67 ECM any help would be appreciated
    SeƱor Tuner MeentSS02's Avatar
    Jun 2005
    Dayton, OH
    1,132
    Which PID are you trying to log?
    It should be something like WB EQ Ratio 1 (SAE).
    2008 Viper - now with HPToona - 1/4 Mile Shenanigans Here
    11.02 @ 130
    Jan 2021
    East Coast
    6
    yes, its the WB EQ Ratio 1 that i have been trying but it noticed it doesnt have (SAE) the crazy thing is when i hit record it disappears
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    Do you see it in the Channels list when connected to the car? It should show up as a 0x7E7 or similar, depending what address it is set as. Default might be 0x7E7, not sure.
    THis is an example, I am not connected to the car, so it doesnt show the exact address, but this shows examples of what you should be looking for.
    Dont choose it from External Inputs.. it's not using those. It's using a CAN address, just like the other GM OBD modules shown in this pic.
    ZL1 Wheels/Tires
    Jan 2021
    East Coast
    6
    Jan 2021
    East Coast
    6
    don't know if it matters but its the gauge that has the pass-thru OBD connection
    Mar 2012
    Detroit, MI
    1,320
    You need to click that little gear icon with the plus when connected to the car, then you should see the menu I'm talking about. You're just showing the channels list, you need to add the channel that I explained. I have two of these OBD gauges, there awesome and easy to set up. You're just looking in the wrong spot.
    Jan 2021
    East Coast
    6
    you were spot on thank you I'm still pretty green with fuel injection and hp tuners it's working like a champ
    Mar 2012
    Detroit, MI
    1,320
    Glad it worked. It can definitely be confusing because it lists the AEM in that other list. Those are for everything non-CAN/OBD based.
    I think you're gonna love that AEM, it's so fast there's no delay so what that means is you can get much more accurate fueling where you need it to be. I've had many others that are much slower including the NGK that everybody says it so great but it slow and it's hard to get it your corrections to perfectly with the actual engine data.. With the AEM you don't need to worry about it, Where it says you need correction is where are you add the correction.
    Nov 2021
    4
    Thank you 10_SS! I was blinded by the AEM menu too.
    Aug 2020
    12
    I'm having the same problem selecting the correct AEM WB channel. Here's my selector. The only WB is found under external inputs. There's no OBD or controllers
    7,894
    How to change the ECU#/PID is described on page 5 of the AEM user manual.
    Aug 2020
    12
    And where can I find the user's manual for WIDEBAND UEGO AIR/FUEL CONTROLLERS
    PN: 30-0334?
    Found it, thanks
    Do I switch to Can mode? PID is not mentioned in the manual
    Aug 2020
    12
    If you're having trouble using the AEM X-Series OBDII WB channel in HPT, try this:
    1. Delete contents of folder, HP Tuners\VCM Scanner\Vehicles
    2. Download current HPT Suite (or Beta) and MVPI drivers,
    3. Connect the laptop to OBDII,
    4. Put the car in service mode,
    5. Wait 20 sec. for WB to power/warm up,
    6. Select mode "obd2" on the AEM gauge,
    7. Close Editor and open Scanner.
    8. Click "connect to vehicle" in scanner,
    9. Repoll vehicle parameters,
    10. Click gear icon with green + "add channel"
    11. [add new channel] dbl click "WB EQ Ratio 1 SAE " under OBD2 [I don't remember the entire tree]. Do not click any External Inputs.
    12. Click "Start Scan", the WB channel should remain in list and display active scan data.
    13. Push ignition button to exit service mode.
    14. Start engine, start scan, and the WB channel should display active scan data.
    So, at least for today, it's working. Thanks everyone.
