Results 1 to 5 of 5
Thread: cut off on deceleration
    ] 2006 tahoe cammed 218/227 with trail blazer ss intake stock throttle body . drive fine ,JUST cut off deceleration sometimes often .any pointers
    learning
    13,621
    I don't understand what you are asking.
    cut off
    [QUOTE=5FDP;643969]I don't understand what you are asking.[/QUote
    If i am driving slowing down for light or stop sign it die. Also if i am park and rev it will die coming back down to idle
    learning
    Mar 2011
    Ripley, MS
    1,865
    The idle speed and min airflow table are pretty close to what I typically end up with for that cam. The overspeed spark table is a little goofy looking. It should be more linear and I'd back off of the peak number a bit.
    It's pretty common to see those throttle body's need a good cleaning. Make sure there isn't a bunch of carbon on it.
    I had an 06 model that I tuned 3 years ago. It ran great for 2 years. Then it begin to go dead just randomly. I replaced the throttle body and it was perfect again.
    thanks .
    learning
