Thread: 2005 F150 Screw 4x4 5.4 3V
    Jan 2021
    25
    Someone has asked me to bump up the idle RPM slightly in the subject truck. I'm not a Ford person, so is there anything else these 3V's like while I'm in there? It's completely stock and not quite 100k miles.
    Thanks,
    A lot of people end up with bigger than stock tires so I go in and set the tire revs per mile for their current tires and max out (or set reasonably) N/V Max Learned
    Jan 2021
    25
    Thank you I'll keep that in mind.
    Mar 2019
    354
    You can go through the full tuning process, there are gains in power, economy and drivability to be had (if that's what the customer wants). I would assume it's the same as a 3v mustang, how much time do you want to put into it?
