Results 1 to 5 of 5
Thread: 10r80 Select Shift
    Sep 2016
    5
    Exclamation 10r80 Select Shift
    Wondering if anyone has gotten the 10r80s to work like a few of the other transmissions, in regards to the paddles. What I am trying to achieve is to use the paddles to get the car to a certain gear..... then go WOT and have it auto shift up from there. I have built tunes for other applications and made this work, however this 10r80 is kicking my rear on this one. I thought it would use the (select shift WOT) under shift scheduling tab. I have tried to input lower than desired OSS numbers equating to about 6k engine rpms with still not results. This table comes stock set to 60,000 so I thought I had figured it out but still no luck.
    Thanks in advance for any input.
    Adam
    Advanced Tuner small tuner's Avatar
    Nov 2015
    271
    interested to know
    6512 and 21567 im pretty sure
    Feb 2020
    4
    Did you guys figure this out? I'm trying to do exactly this.
    Oct 2009
    48
    You have to set the desired WOT shift OSS very low and it will work.
