Results 1 to 12 of 12
Thread: 2013 s8 zf8hp
    Sep 2020
    12
    2013 s8 zf8hp
    I previously had a 2013 A8L and successfully reset the Amax counter and modified to keep Amax engaged through 5th gear. I'm using DS1 for ECU tuning and on the A8 I could set launch torque.
    I recently picked up a 2013 S8 and I'm looking to get some help tuning the transmission. The controller is a LOT different than my A8. I've adjusted for Amax to stay active through 5th gear and reset the launch counter. Unfortunately, it doesn't seem to be engaging amax. Also changing the launch torque in the ECU has no effect. I think the trans is deciding launch torque. I know I could pay someone to tune it for me but I like to learn. If anyone has some ideas on what might be happening i'm all ears.
    Thanks,
    Duke
    post a copy of your tcu file
    Sep 2020
    12
    https://drive.google.com/file/d/1GBb...ew?usp=sharing
    Link to my stock trans tune file.
    check pm
    Aug 2021
    10
    Does enabling AMAX through 5th gear have some benefits that you have actually seen a noticeable difference and measured?
    Tuner in Training ezhik89rus's Avatar
    Jun 2021
    16
    Sorry, can you share the mod file for the A8 tcu? I want to compare, am I on the right track?
    Aug 2011
    3
    Did this one ever get solved? I am having the same exact issue with a 2013 A8. Thanks!!
    Mar 2023
    Having a similar issue with my AMAX too =/
    Aug 2011
    3
    I ended up reaching out to Silly Rabbit and got a tcu tune from Etspec and it resolved all of my weird issues.
    Aug 2021
    Indianapolis Area
    459
    Quote Originally Posted by NisseJarnet View Post
    As we talked, depending on the changes you did, tranny will automatically deactivate AMAX in case tune is outside boundaries/thresholds.
    DodgeBoy.
    YouTube: https://www.youtube.com/@dodgeboy2785
    Quote Originally Posted by HydroStrm6 View Post
    Do yourself a favor, and send it back. Either custom tune it via HPTuners, or if you want an OTS file, hit up Leistune.
    To the best of my knowledge, Leistune is the only company modifying maps beyond what HPTuners has defined out for modification in the TCU.
    Aug 2011
    3
    Quote Originally Posted by Kaploww View Post
    Why would I do this when it resolved all my issues? ETSpec also has access to parameters not defined by HPT. They're using the same software John is (winols), except John is a giant douche.
