Page 3 of 3 FirstFirst 123
Results 41 to 48 of 48
Thread: Intro to Mercedes 63 AMG (ME97AMG) Tuning
  1. #41
    Apr 2021
    MD
    51
    Could we get a guide like this for the M278 M157 platform?
  2. #42
    Dec 2019
    California
    24
    Is the 7G Tronic transmission supported? I read from a W204 C63 and the OS for the TCM populated but the hardware doesn?t.
  3. #43
    Feb 2012
    Central KY, South FL
    15
    Really would kill for me9.7 support for my daily m273 w212 e550
    Spent a decent amount of time on our m278 e550 with hpt..
    Its a damn rocket but I am still struggling with throttle limiting, and getting rid of the cut that stops you from brake boosting from a roll.
    If I can address those last two things figured out.. this thing will get down like a clown for a street car.
  4. #44
    Oct 2019
    CT
    34
    his problem is EGT
  5. #45
    Oct 2019
    CT
    34
    how do i adjust the boost?
  6. #46
    Mar 2023
    9
    Any one know what is max throttle angle on the M156? On full throttle pulls, only getting 86% reported with limits set to 100%. Just wanna know if that is max limited by hardware and not a software issue.
  7. #47
    Jan 2022
    Southern California
    410
    On my car a 100% throttle command nets 86.7 at the throttle. 85.5 to 87 is the max I see on other benz, which I assume is what the sensor sees when the throttle is against the stop. The most I've seen mine closed is a command of 1.6 and the position reads 12.5. I assume that is against the other stop.
    You can also do a throttle check with Xentry, and no doubt other tools, where it fully opens it and reads the same 86.7 on mine.
  8. #48
    May 2024
    7
    Hi gents, how can I scan the vehicle in order to see wich "VAR" or vehicle variants is?
    I beliave my c63 is VAR 4 because of throttle limited but I'm not sure. thank you
