Hi,
I try to remove the VSS Limit ,106mph can?t be crossed, anyone can help me,many thankx
Hi,
Hmmm? Strange. The speed limits are under the Speedo, then Limiter tab and they're set pretty high already. Well above 106mph. Have you flashed this map to your truck?
`21 Explorer ST Rapid Red = Fast/Fun SUV????
`18 Ford F-150 Raptor Lightning Blue = The Super/Fun... Truck!
`17 Ford Focus RS Nitrous Blue = The Super/Fun Car
`11 Ducati 1198SP SuperBike Ducati Corse = The Big Dog
`12 Ducati 1100SP EVO Hypermotard Ducati Corse = The Hooligan
`15 Honda CBR 1000SP Repsol = The Last One...? (no)
`21 Aprilia RS660 Apex Black = The smallest...
Yeah, I was thinking the same thing, set at 186, so speed limiting shouldn't be an issue. But after looking at the rest of this tune, I wouldn't run it. You got some limiters off the scale, raise them yes, but not that much.
Yeah, I don't know if the OP is making the changes, or some other tuner. Based on the question, it's not likely the OP though...
speed limit vs gear and speed limit vs shift id needs to be changed
Where do you want the limit at ? If you go in to speedo - Limiters, you'll see they have it set at 158 MPH
Hey Mark.he, have you sort out this problem? I've got the same one with 2018 Ford Escape 2.0T. I've changed all values under Speedo->Limiter, and Trans -> Shaft Speed -> OSS max as well, with no luck. The ECU always cuts torque at about 110mph and VCM Scanner shows "vehicle speed limit" at driver demand limit source.
Regards,
