Howdy, I just finished up my LSA blower install on my G8 GT. I have the tune setup to where the car starts, idles, cruises just fine, but when I do a WOT pull I wind up in "safety mode". I have the p0068 test set to not run until 8000 rpm and the p101/106/121 tests to not run until 240 degrees so I dont think that's the issue. Could it be my gold blade throttle body shutting things down? I also noticed my air fuels are a bit sporadic when I'm in boost so I'm wondering if there is just something set up wrong in the tune itself. Any help is appreciated!
Tune is attachedG8 6.0 LSA FID1000S pump gas.hpt
Thank you![]()
