Results 1 to 5 of 5
Thread: my Phantom Codes (?)
    Advanced Tuner Boost's Avatar
    Dec 2006
    Florida, USA
    303
    Arrow my Phantom Codes (?)
    These 4 codes are set as permanent despite multiple erasing's and test drives.
    They are not causing the engine light to be illuminated or any drivability symptoms I am aware of.
    I call them "Phantom Codes".
    Any info ??
    '12 Caprice PPV 6.0 L77 - daily transportation
    8.7 @ 84 (1/8 mile) bolt-ons
    '02 Silverado RCSB 5.3 L59 - regularly street driven
    8.2 @ 86 (1/8 mile) stock cam and spray
    8.6 @ 84 (1/8 mile) cam and heads no spray
    Our YOUTUBE CHANNEL featuring the Silverado
    Dec 2006
    Florida, USA
    303
    Thanks!
    Dec 2006
    Florida, USA
    303
    thank you that is great info and new to me - will try it for sure
    8,053
    If a permanent code is already set and you then go and disable the code that enables the diagnostic to run, it will not clear the permanent code, it will do the opposite - cause the permanent code to NEVER clear, even if you correct the condition that caused the code. The test(s) have to run and pass a certain number of times before the code will go away.
