Results 1 to 11 of 11
Thread: Wild spark, unstable idle after flash
    Mar 2020
    Western Canada
    91
    Hello
    2015 C7 stingray z51
    First time flashing a gen 5 LS ecm,
    Made some changes to the stock file, flashed it, car wont idle or drive correctly, spark is unstable,
    p0300 misfire codes, flash back to stock and all is well...
    odd???
    anyone else have this issue?
    Fixed after re-reading stock file and re-editing it.
    Nov 2009
    All Around
    3,149
    which version of software are you using?
    Mar 2020
    Western Canada
    91
    Quote Originally Posted by SultanHassanMasTuning View Post
    Newest stable version, updated it last week, could be due to deactivating too many dtcs. Or not downloading the stock file after holding down the ignition button for 6 seconds to get the vehicle into true KOEO.
    Nov 2009
    All Around
    3,149
    try to disconnect battery for a while and connect.
    Nov 2009
    All Around
    3,149
    i always hold down the ignition key for 6 to 7 seconds to read file
    Aug 2009
    Calibrating
    3,378
    My first question would be what changes are you making
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Mar 2020
    Western Canada
    91
    Vehicle has long tubes
    I believe the issue was o2 sensors> feedback> i set it to single instead of the factory setting of dual
    Or it was disabling all of the o2 sensor 2 codes.
    Haven?t had an issue now since i reflashed it to stock and then reread and made all the changed only to the dtcs that came active on their own and leaving the o2 feedback setting alone.
    Mar 2020
    Western Canada
    91
    Thanks for this, i read it on another thread and it was the only way to flash entire due to timing out.
    Nov 2016
    29
    Had the same problem with a 6th gen camaro that was tuned before , if I ever change any parameter on the file regardless what it was , the car wont be stable at idle , I have ended up loading a stock file and start over . Still have no idea what was the problem .
    May 2003
    South FL
    1,395
    Does the car have one of those Pedal Controller units that plug into the gas pedal? These will cause all sorts of issues every time you flash a car. They must be removed when flashing.
    [email protected]
    Owner/GM Calibrator
    Mar 2020
    Western Canada
    91
    Car is completely stock other than long tubes.
    Problem was fixed by flashing back to stock and then downloading the stock file again.
