use the run position, but make sure its as far forward as you can get it with out starting the truck.
I got the 03 to read after a few tries in low speed mode. I wish we could get a resolution on this soon. Even if low speed works first try, it's still about 25 minutes just to do a read. I have not yet had trouble writing a calibration on 03 or 05.
2005 Sierra Z71 SLT CCSB (LM7)
STS GT67, LPE GT 2-3, ASP Pulley, Delphi 42#, A'PEXi AVC-R, PLX SM-AFR, FLT Level 5 4L65E, PI Vig 2600, HP Tuners with 2-Bar SD OS (Plus some smaller mods)
Support our Troops
Yup, same exact problem I have. I have not tried reading another vehicle yet. I was hoping to this last weekend, but was not able to make it out to the local GTG we had.
I would be happy to be able to have a check box or something to just read the VCM or the VCM and TCM. I will rarely read the TCM at this point, and if I get the 6 speed upgrade, sounds like I won't be able to read it at all.
Jon
2012 Ram 3500 6.7 Cummins with Banks CAI, intake tubes, intake horn, grid heater/EGR/DEF delete, 4" Straight pipe
2017 Jeep Wrangler Rubicon Unlimited, Stock - but looking to change that
What happens if you guys disconnect the TCM for reads?
it would probably just cancel the entire read unfortunatly
Did a 02 this morning
under 7 minutes.
But,I can't edit the file,not supported.
is this the error you came across when trying to edit it? http://www.hptuners.com/forum/showthread.php?t=2929Originally Posted by Motion427
Yes, that's the error I received.Sent to support.
still waiting......
it just means they havent added that particular definition file yet, mind posting the file? If I can open it with my beta version I'll send you the link to try out
Your more than welcome to have a look,I know everybody is busy,I'll have to wait my turn LOL......
have a look
I also tried it with 2.1.15 Beta.
No go....
yeah, looks like Chris will have to hook you up...im not able to open it with the latest beta
Thanks for trying!!!
I did another 03 last night. Worked first time in high speed mode. That was a great suprise.
Support our Troops
