A question for you all. I've an iPhone 12 Pro Max but I can only select the front or the "normal" back camera. Is there a way to use the wide angle or the tele lenses too?
Thank you in advance for your help!
Maurizio
Maurizio
I know but I'd prefer to be able to record video from TrackAddict. There's no way to record video with a different app and use track addict on the same device at the same time. Should be fairly easy to implement in the app…
BTW, low light on the iPhone 12 Pro Max is quite good.
