Results 1 to 3 of 3
Thread: Flashing a stock tune to a junkyard ECU
    Oct 2021
    3
    Probably a simple question, but I have a junkyard E67 from an Impala i need to flash to run my 2009 trailblazer 4.2 for a swap. Can i simply flash one of the stock tunes from the repository, or will i have to get programming from the GM website in order to get the base 4.2 config on here? Thanks fellas!
    13,615
    You'll need to use the GM tool. There are a few segments that HPT can't flash but the dealer tool can when it comes to full on re-writes.
    Oct 2021
    3
    Thank you sir! I was hoping to save a step, and the money the GM website charges..
