So ive been researching but have come to a dead end.
2011 Corvette GS running 2 bar OS. Running a return style system with a 1:1 regulator hooked to vac/boost source. I've set all my injector data up per Fuel Injector Clinic data, set my IFR to constant 66.7(Double stoich/ Half IFR/IVT) Am I missing a table to modify for my regulator and system(Fore Innovations)? Ive read that the Offset vs pressure delta vs IGN needs to be adjusted for a 1:1 boost ref regulator. How do you go by doing this? Im seeing conflicting responses during my search and want to verify this isnt the cause of my lean issue at light part throttle tip in. I can have my fuel trims at less then 1% and during slow sweeping throttle increases it will lean out to the point it breaks up. Tune is attached. Ive yet to really get out of part throttle tuning as im still breaking in the clutch so MAF above 7000Hz isnt really touched yet.
