Results 1 to 5 of 5
Thread: 03 ecm dbw/ 024l60e trans. Input speed sensor code
    Oct 2013
    7
    Just swapped a 4.8 into my s10 and getting a code for no Input speed signal. The way I've read is the 07 and up 4l60e transmissions had that sensor. Do I just disable the MIL code in the setting?. The ecm and harness is out of a 03 6.0 4l60. The engine I have is an 07, but I'm not using that ECM.
    Oct 2013
    7
    Just checked the original ECM. Was a 2004 engine. Do I just need to use that ECM instead? I have 6 different ECMs laying around. I would just rather not spend the credits when I already have that one set up for the s10
    8,090
    Why not plug in the '04 PCM, do a read, and then compare the '04 file's DTC settings with the current file? Then just make them the same?
    Oct 2013
    7
    Everything is exactly the same but this part of the tune, where there is a difference in the ecms
    4.8 ecm
    6.0 ecm
    8,090
    So that means you have P0716/P0717 set to No Error Reported and still getting a code for ISS?
