Results 1 to 8 of 8
Thread: Help with power enrichment
    Mar 2018
    32
    I cannot seem to get this tune to go into PE at WOT.
    Any help or suggestions would be greatly appreciated.
    Thank you
    Mar 2018
    32
    Here is a log to go along with the tune.
    Mar 2018
    32
    Anyone??
    Oct 2021
    28
    I'm not really any help here but I do remember coming across a similar post lime this while Google g Google g doing research.
    Jun 2020
    814
    I don't know for sure, but I compared your file to some others and I think I would try enabling OP Enrichment Required (ECM 44422) and lowering Cat Protection Max Enrichment (ECM 44549) to .7. Neither SHOULD affect it but it SHOULD be working and isn't, so who knows.
    Also, your knock advance doesn't seem to be working so that might need to be looked into as well. I know if it senses that the IMRC isn't functioning correctly, it won't allow knock advance. I don't know what other underlying faults could cause it to not enter PE mode.
    Mar 2018
    32
    Thanks for your reply Lightning, I have looked closely at the post you cited and continue to study it. I've all but searched through lots and lots of posts. I only post my tune and ask as a last resort.
    And I appreciate anyone taking the time to help. Thank you!
    Mar 2018
    32
    Thanks to you also engineermike.
    I'll try your suggestions.
    I do have knock advance zeroed in the higher loads in table 44684 for safety at this point.
    I'm also only running in mapped points 14-26 to keep IMRC open(among other reasons).
    Again, thanks for taking the time to help!
